| By Magic on Saturday, September 28, 2002 - 02:45 am: |
Anyone any suggestions(?) on the best method of checking the oil level, to get an accurate reading? Ta.
| By John1000 on Saturday, September 28, 2002 - 03:40 am: |
Short of draining all the oil out and measuring it no. Just know be careful if using the sighting tube as if you fill it near the Max level, when the engine gets hot the clutch is hard to use so take it for a test before riding to far.
| By Crmc33 on Saturday, September 28, 2002 - 03:47 am: |
Magic,
I think Ive read b4 that Aprilia have more problems with bikes that are overfilled with oil than underfilled.
Personally, I find it difficult to get a consistent oil level reading, so as long as theres some oil in the tank after a decent run (10 miles or more) then Im happy.
| By Racerxlilbro on Monday, September 30, 2002 - 06:16 am: |
Here's the trick:
Make sure the bike is up to temp... at least 10 minutes of riding. Shut the bike off. Oil should be just peeking in the bottom of the tube. If it doesn't, start the bike, hold it about 3500 RPM for about 15 seconds, recheck. Works for me...
| By Twowheels78 on Wednesday, October 02, 2002 - 10:00 am: |
Here's how I do it....in, out, in, out...oh...opps sorry forgot that we're talking about oil here
To check the oil level, get the bike up to temp, check the level with the bike running and vertical, the level should be in the middle (even with the horizontal fin on the engine cover). At least that's how I do it and it hasn't failed me yet. If I recall correctly this topic has come up before and this is the conclusion that everyone came too.
One more note, make sure to check it often (I check mine every 1000 miles or so) as the bike seems to use quite a bit a oil, at least mine does. If it's low top it up but don't fill it all the way to the top, when the bike warms up the level goes up.
