| By Andyjfalco on Tuesday, August 13, 2002 - 05:08 am: |
I'm using a Factory Pro chip with the eprom wire uncut. The bike seems to be running a bit rich although it's not giving any problems. Will I be better off cutting the wire? I've also fitted an air kit and Skorpion exhausts. Cheers guys.
| By Edzo on Tuesday, August 13, 2002 - 01:08 pm: |
don't cut the wire
on the factory pro chip, wire connected is map 14
wire disconnected is map 13
both maps will run rich if it is rich now (mine is a wee rich too)
talk to fcatory pro about what you can check to make the bike less rich, or get the chip fine tuned by factory pro.
I suggest installing a toggle switch on that wire, and run connected for a month, then switching to the disconnected mode for a while, and then decide which map you like best and then stay with it.
I has stock cans and it was rich, now I have Giannelli's and it is less rich. it is about right now.
| By Andyjfalco on Tuesday, August 13, 2002 - 02:29 pm: |
Cheers Edzo, I did think of a toggle switch but realy if it's not that different, I won't bother. (If it aint broke, don't fix it etc...)
