| By Oab97 on Thursday, August 01, 2002 - 10:26 am: |
Anybody tried, or know the effects, or putting shorter "SP" type velocity stacks on a Falco?
| By Stefan on Thursday, August 01, 2002 - 11:55 am: |
Good question, i`d like to know that too.
| By Crmc33 on Thursday, August 01, 2002 - 12:32 pm: |
Id expect very little difference apart from a lighter wallet!
Remember that the SP engine is a totally different beast to the cooking Mille engine. Its inlet dimensions/tune is likely to require quite different tuned tract lengths etc.
If the shorter stacks do anything for the normal engine Id guess that it may give a fraction more top end power at the expense of midrange. IMHO, this is the usual effect.
| By Prilliant on Thursday, August 01, 2002 - 01:06 pm: |
As far as I know the Mille SP has different bore & stroke and runs with single plug per cylinder heads. Can't imagine the new stacks would make a noticable difference. Could be wrong mind. Stranger things have happened. Sounds bloody pricey.
| By Oab97 on Thursday, August 01, 2002 - 01:32 pm: |
I appreciate the inputs on the potential performance change, or lack thereof.
FYI though, a set is only $36 U.S. from evoluzione.net so the wallet concerns seem a bit overblown to me.
| By Powermaster on Thursday, August 01, 2002 - 01:40 pm: |
Why don't you try them OAB and tell us all about it
| By Racerxlilbro on Thursday, August 01, 2002 - 04:21 pm: |
***FYI though, a set is only $36 U.S. from evoluzione.net so the wallet concerns seem a bit overblown to me.*** Be careful, they MAY make less power than stock!
| By Racerxlilbro on Thursday, August 01, 2002 - 04:22 pm: |
Just kidding, Ken.
| By Befbever on Friday, August 02, 2002 - 06:56 am: |
@ Powermaster.
| By Crmc33 on Friday, August 02, 2002 - 07:06 am: |
Stop stirring the pot again Bef!
The MowerMaster, err I mean PowerMaster was just trying to be impartial and was almost getting away with it till you wrote that last comment
I am ashamed of you. You know that my secret 18 inch long trumpets work the best. Doh!
| By Befbever on Friday, August 02, 2002 - 07:09 am: |
So your Falco runs like a stroker now, does it? Powerband from 10.000 until 10.500 rpm, is it?
18 inch long trumpets. Doesn't that hurt?
| By Racerxlilbro on Friday, August 02, 2002 - 08:08 am: |
***18 inch long trumpets. Doesn't that hurt?*** Not me!
