| By Scottaride on Tuesday, July 16, 2002 - 09:27 pm: |
Does anyone have them and do you need to cut the fairing?
| By Fastdaz on Thursday, August 01, 2002 - 07:44 am: |
HI scott, seen a set of r&g protectors on a rsv last weekend, they looked pretty good, no mods to bottom sliders but top ones require a 25mm hole through black panels (just behind fans).
I ordered a set a couple of days ago from rsvr.net, hopefully i can fit before first trackday pretty soon.
cheers daz
| By Nick on Thursday, August 01, 2002 - 08:36 am: |
A pic of the R&G bobbins fitted
| By Taffrsv on Thursday, August 01, 2002 - 08:40 am: |
I have just fitted a set, when fitting make sure the washers on the top bobbins fit on to the machined spot faces on the engine mount not the cast part or you will not get a tight fit and they could flex and snap off if you drop it.
| By Taffrsv on Thursday, August 01, 2002 - 08:41 am: |
foook me someones got the same bike as me
| By Fastdaz on Thursday, August 01, 2002 - 02:11 pm: |
Taff,
obviusly you fitted them yourself, what did you use to make hole for top fitting, top tips much appreciated
cheers daz
| By Taffrsv on Thursday, August 01, 2002 - 02:17 pm: |
follow the instructions with the bobbins, then open out holes using a dremil, be carefull with this tool they seem to have a mind of there own, also make sure you take the foam padding off behind.
| By Fastdaz on Thursday, August 01, 2002 - 02:28 pm: |
Taff
BTW what lap times were you doing at croft?
| By Taffrsv on Thursday, August 01, 2002 - 02:40 pm: |
slow
I never pushed myself the main thing was to have some fun and come home in one piece, and I have to admit I could not suss out the damn lap timer
| By Fastdaz on Thursday, August 01, 2002 - 02:56 pm: |
Taff
sorry to bug you, but seen some pics on aprilia forum about airbox mods, i know you made your own kit, can you send some pics of mods and info on what you used as base plate (i'm a big fan on diy if you can), btw seen your tyres after croft (takin it easy i bet) cheers Daz
fastdaz@btinternet.com
| By Boosta on Friday, August 02, 2002 - 01:13 am: |
hehe
you should stay away from those Pr0n sites DAz
get a rene air kit, you know you need one :P
Boosta
| By Rsvdave on Friday, August 02, 2002 - 05:12 am: |
Scottaride,
I'm using the Motrax Top Blocks. Solid piece of kit (if not the cheapest) and were dead easy to fit. They only do the lowers and require no modifications.
RSV Dave
| By Webhamster on Friday, August 02, 2002 - 07:09 am: |
I can't reccommend the R&G ones highly enough personally.
| By Boosta on Sunday, August 04, 2002 - 09:21 am: |
R&G ones work a treat, pics will foillow
| By Scottaride on Sunday, August 04, 2002 - 06:27 pm: |
Thanks for the advice
