| By Nickp on Wednesday, June 19, 2002 - 10:57 pm: |
Please could one of you top RSV blokes have a look in your handbook and tell me what the std setting are for a Y2K RSV sachs shock ? I'm just upgrading the rear of my poor saggy Falco. Cheers in advance.
| By Diablo_Mille_R on Wednesday, June 19, 2002 - 11:48 pm: |
This is from the 2001 owners manual, I don't know if the 2000 model is the same or not.
Rich
| By Crmc33 on Thursday, June 20, 2002 - 12:23 am: |
I have the Y2K shock fitted to the Falco and it is a little different.
Have you seen the thread on the SL1000 area called '01 Mille rear shock' , last edited on May 23?
Im using a similar damping/spring setup to that stated by Hansie and the bike handles well.
| By Nickp on Thursday, June 20, 2002 - 12:26 am: |
Nice one Rich. Cheers for the quick response.
I think it is different. It certainly looks different, but maybe the settings are the same ?
Does anyone have the Y2k version ?
| By Nickp on Thursday, June 20, 2002 - 12:36 am: |
Crmc33,
I was that busy looking at the pretty piccies that I didn't see your post.
Yes I have seen that thread and will probably start with those settings (are they FB compatable?). I just wanted to compare them to the STD settings.
| By Crmc33 on Thursday, June 20, 2002 - 12:38 am: |
The shock is different and the settings are too.
If you use Hansies settings stated as a base you wont be far wrong.
I have dropped my front yokes down to further quicken the steering but that is to compensate for the slow steering nature of the MEZ3's.
If I were to fit the y2K shock to a bike with more 'racey' rubber then Id wind the rear ride ht upto max, set the damping as stated and go from there.
HTHISW
| By Crmc33 on Thursday, June 20, 2002 - 12:42 am: |
I think our threads are crossing on the way to the satellite!
FB compatible? Do you mean persons of large proportions?
Depends how much of a FB they are!
| By Rca on Thursday, June 20, 2002 - 01:21 am: |
Nick,
The settings for the 2000 Mille standard shock.
Shock absorber distance between centers Std 322 +- 1mm, Race 322 +- 1mm, Poss adj. 320 to 327
Spring length preloaded Std 130, Race 128, Poss adj. 128 to 132
Adj. with ext shock Std open 14 clicks, Race open 7-9 clicks, Poss adj. 25 clicks
Adj. with comp shock Std open 35-45 clicks, Race open 20-30 clicks, Poss adj. 45 clicks
Russell
| By Nickp on Thursday, June 20, 2002 - 02:15 am: |
Cheers fellas.
For RACE can you read Fat B*stard ?
| By Mr_Venjer on Thursday, June 20, 2002 - 04:51 am: |
What is an SL1000 ???
Why does my emoticon list not work ? I want the man ducking behind the chair icon ......
Venjer
| By Crmc33 on Thursday, June 20, 2002 - 05:29 am: |
/clipart{sofa} but with a back slash instead of the fwd slash
