| By Benw on Tuesday, July 30, 2002 - 12:45 am: |
A question to those of you out there with the Rene airkit - what do you clean the filter with?
Paraffin? Seems the logical solution.
Anyone use owt else?
| By Mark on Tuesday, July 30, 2002 - 01:54 am: |
I wouldnt use Paraffin personally. A low flash point solvent is better, probably best to ask Jorge what to use.
| By Benw on Tuesday, July 30, 2002 - 03:17 am: |
I don't want any flashing at all!
Solvents might attack the glue holding the filter parts together.
I 'spose I could get some of the castrol foam filter cleaner...
| By Crmc33 on Tuesday, July 30, 2002 - 04:04 am: |
Sounds like that should do the job.
Either that or use a can of nitromors and a blast with a 600psi compressed air line. That should clean the bugga
I'd do it sooner rather than later. Just think of the weight saving once youve cleaned all that dust out of the filter!
| By Benw on Tuesday, July 30, 2002 - 05:53 am: |
Paraffin is the stuff. Called Jorge and that's what he says.
Ok, gonna go clean it now, see how much crap there was hiding away in there...
I could probably lose more weight by sneezing!
| By Salkhan on Tuesday, July 30, 2002 - 06:31 am: |
K&N filter cleaner should do the trick as well.
| By Powermaster on Tuesday, July 30, 2002 - 06:53 am: |
Ben is on a freelance job, he can not afford K&N
| By Crmc33 on Tuesday, July 30, 2002 - 07:05 am: |
I once cleaned the brake disks n calipers on my CBR600FM with parafin. I went out for a ride to the pub and when I got there the brakes were smoking and had gone bright blue!
Looked well cool to passers-by!
Not so good for the brakes tho
or for keeping clean underwear when the lever came back to the bar (the fluid was boiling too).
Im much more sensible these days (as Im sure youve noticed).
I use WD40 now instead
| By Racerxlilbro on Tuesday, July 30, 2002 - 07:25 am: |
***I use WD40 now instead***
Daz, you hear that? Maybe this is your solution! Oil the brakes!
| By Crmc33 on Wednesday, July 31, 2002 - 01:39 am: |
Ben,
dont forget to re-oil the filter once you've washed it. I always use warm pork dripping on my filter as its runny when warm but firm n sticky once set. This almost sounds convincing!
HTH.
